Old 02-01-2009, 12:24 AM
Frosty's Avatar
Frosty Frosty is offline
Rep: 1693 Posts: 5,809
2 pot eurothane.
I have a gallon of 2 pot euorthane and have lost the hardener. I am told I can't buy some without a new gallon of paint,--its not cheap.
I have tried epoxy hardener and some Jotun hardener without success,
Its Joton Futura AS--white, Does any one know a way to get it to go off so as I can use it?
I am just testing polyester resin hardener in the sun at the moment but not looking good.
Im only painting the dinghy!!
vinigar , bleach, hair shampoo, cellulose thinner,???????
Old 02-01-2009, 01:46 AM
CDK's Avatar
CDK CDK is offline
retired engineer
Rep: 1416 Posts: 2,241
The hardeners for polyurethane contain isocyanates, just like superglue.
Loctite Hysol and Loctite 3183 are commercially available hardeners.
You could try a few drops of superglue, but then you probably have to paint very fast!
Old 02-01-2009, 01:53 AM
TeddyDiver's Avatar
Gollywobbler
Rep: 1348 Posts: 2,043
Seems you need 50 helping hands..
Old 02-01-2009, 02:50 AM
Frosty's Avatar
Hmmm interesting,---how fast will I have to paint?
A few drops of super glue to how much paint?
Old 02-01-2009, 08:49 AM
CDK's Avatar
CDK CDK is offline
retired engineer
Frosty, I have no idea. But when faced with your problem, I would do a small scale experiment. Using the paint without hardener leads nowhere: I did that once because the tin with the hardener got displaced and the paint tin carried texts in funny languages only, so I thought it was single component paint.
Because it was still wet after a week I started searching and found the hardener. But spraying it over the paint didn't help anymore....
Old 02-01-2009, 09:09 AM
Frosty's Avatar
I understand exactly what you are saying.
Ive done that many times myself. Anyway I tried a single drop into a half a teaspoon bit of paint but after 5 hours its still soft.
Hopefully in the morning its cured or ille try more super glue.
Old 02-01-2009, 11:59 AM
robherc robherc is offline
Designer/Hobbyist
Rep: 102 Posts: 433
I just did a little research on Google. Wasn't able to find any listing of any specific chemical(s) that will cause it to harden. I DID, however, find information about using different "reducers" to alter the gel time, maybe you could use a slightly "faster" reducer & get a decent set w/o part 2?
northern lights 3 pot lazeyjack Diesel Engines 0 08-14-2006 04:23 PM
Also have a gel-coat gun and 2qt pressure pot cla17 Marketplace 2 08-02-2004 12:01 AM
